You can do it yourself. So, you screwup a couple pieces of tubing learning. It will still be a lot cheaper than having someone make them for you. I had to make them up at work on trucks that went up the mountain into the snow. They would break a snow chain crosslink, and it would shear the brake line off of the wheel cylinder. They wore the crosslinks down so far that they would break. I got pretty good a making new lines but then I retired and hadn't done it for a while. I screwed up a couple pieces of tubing. I started with the long pieces and if I made a mistake, I used it over for one of the shorter pieces.
So the very first thing you do is practice making a uniform flared end. First you want to make sure the end is cut straight. That the end of the tubing is just slightly chamfered with a file, this helps form the flare. So does a little oil on the brake line, right where the flare is happening. That the end of the tubing is sticking up the right amount while clamped into the flaring tool. Then crank the handle until you have a nice-looking flare. Look at the flare and make sure it's straight, that the flare is equal around the tubing. Then if you made a beautiful flare congratulate yourself and then cut it off because you forgot to put the nut on the tube before you flared it.
Bending the tubing and getting it perfect can be a challenge. What has worked for me is I took a bunch of old tubing, and I bent small pieces from 5 degrees to 45 degrees. I marked them with a sharpie marker where they lined up in the bending tool. Then I took two of them and put them where they were going to go and measured the distance between the sharpie marks. When I line up the bending tool on the sharpie mark of the tubing and bend it, it will be exactly the correct length between the bends. You'll screw up some of them, but those pieces get made into little bending tools that you will eventually use, so there not wasted.
The bending and flaring tools. They make them with sharp bends, wide bends, so use the bender that will give you the bend you're after. The flaring tool, they make ones that flare really nice and ones that are junk.
I always mark the tubing with a sharpie where the bend is going to start, according to the bending tool, and I make sure the bender is set at zero. I make that first bend and then I lay out two pieces from my scrap pile and measure the distance between the two sharpie marks on the scraps. That way I know where to lineup the bender for the second bend. Here I'll show you two pieces of junk tubing with the sharpie marks. I measure the distance between the marks and then transfer the marks to the real peace of tubing, then line up the bender on the marks and make the bend. I end up with a piece of tubing that fits in the spot.
This is a '32 chassis I started on years ago and it's just sitting there now, unfinished. The temporary rearend in there is a late '32, with the axle housings flipped upside down to lower the rear of the car. It has '36 Ford rear arms on it. I was going to adapt those '36 arms but now I'm not sure. Not all my experiments work out.
