40ford
I put a used fuel pump I had on tonight.Thought I would try this first.Had a very hard time getting 40 to crank.The bowl filled about half way up.I poured a little gas down the carb and it would run for a few seconds.I took the gas line loose going to the fuel pump on tank side with no site of fuel in the line.I blowed the line out all the way to tank.I finally started filling the gas line back to the tank and she fired up and ran OK.I thougt it was strange that there was no sign of fuel when line was taken loose at first.Sounds like I almost have a problem at tank.How can I get trash out of tank without removing it from car?Can I see inside tank if I remove sending unit?I will drive her a while to see if changing fuel pump makes a difference.
