I already discovered that the rear latch for the 40 Ford Sedan Delivery is for the S/D only. It seems Ford had a different latch for every position and every application. I count at least 7.
Anyway, I ordered new exterior handles from Drake and the shaft on the ones I received are too short for my S/D latch. Does someone make a reproduction handle with a longer shaft? Do I have to cut and weld an extension onto the short shaft version?
What other oddities will I encounter on my Journey. I already figured out that the cargo door scuff plate isn't available. I will try to cut down a Tudor version for that.
Thanks for your help.
