The 40 Ford rear hub has two snap ring grooves. Why? The outer one is familiar – it retains the grease seal. The inner one – positioned so it could retain the bearing - seems unnecessary. Is it used?
Also, in searching the Green Book for information, I see the GB lists part 78-1184-B “washer (rear wheel bearing thrust)” (used 40-48). That "washer" is rather large (2.8” OD x 3/8” thick). Where does it go? Being 3/8" thick, it could fit between the two snap ring grooves. But why?
