'40 Ford LED Tail Lights
LED's are polarity sensitive, so you need to specify you're running positive earth when buying. There are some that are not polarity sensitive, but they must be specified.
I'm running LED's in the rear of my 41 (after seeing Merc Cuzers' vid- thank you Sir) and I can attest they are real attention getters.
Glad I could help.
The pins on my 40 taillight bulbs are off set.Is your 41 the same way?If so what is the part # on the bulbs you are using? Thank you Merc Cruzer for video!
I have Red lenses with Blue Dots. Basically the output for these bulbs, is the same as an original headlight bulb.
I have always look at pictures as "they are worth a 1000 words" and should be self explanatory, and my original picture wasn't. So it is a better one for the file.
Well; back to square one. I need single contact tail light/brake light bulbs in my 35 PU, Unfortunately the numbers on the bulbs are illegible. I think the smaller one is a 63 and the larger one a 1073, but I'n mot sure about that. Can anyone give me the correct numbers for the bulbs I need so I can order LEDs. The set up on the 35 is a single contact with locking pins straight across from one another. One is larger for the brake light. One is smaller for the tag light.I unfortunately ordered dual contact bulbs, which are not what I need. I am slowly acquiring an unneeded collection of misc. LED bulbs.
NEVER MIND. I found both bulbs in LED. Larger one, cheap. Smaller one expensive. Go figger.
i just ordered 2 bulbs from ledlight.com acording to them they replace 1154 6v pos groung and they recommend red bulbs if you have red lens.will let you know how that work when i get them the are based in AZ usa
recieved 2 bulbs from ledlight today both not working ,my 1154 bulbs work fine but not bright enought spent over $30 in bulbs made in china im done:mad:, buyer beware
When I had bad unit (LED headlight) I call them and told them of the issue they sent me a new one at no cost.
www.ledlight.com
Contact by Email
SALES & SUPPORT - sales@ledlight.com
Contact by Phone
Toll Free 1 (877) 283-5060
Local 1 (602) 997-0366
No mods, just plug and play.
Just curious, have you tried using jumper wires from the bulbs to a battery, out of the car?
I just looked back, and my purchase was 2 yeas ago. I just tried to call them and no answer for sales or support. I will try again tomorrow. I will post the response.
If you guys used PAY PAL get a refund through them.
Yes Pls let us know if these new ones from ledlight.com I got them and they dont work.
I got two ordered and on there way.I am real curious to see if they work.I will give an update when I try them.
I just got off the phone with David at ledlight, and the bulbs are warranted for one year. If there is an issue just call him: 1 (602) 997-0366
He did mention that the offset pin bulbs are BAY15D Product Code: 64854
