R russcc Well-known member Aug 8, 2017 #1 What other locks does the ignition key fit on a '40 coupe, providing they are original locks. Door ?, glove box ? Trunk ? Thank you Fordbarners.
3 32phil Well-known member Aug 8, 2017 #2 Ignition and door lock were/should be keyed the same. Trunk and glove box locks were keyed the same (not the same as the door & Ign.) Tire locks, usually an option, were keyed by themselves.
R russcc Well-known member Aug 9, 2017 #4 Thank you 32phil. Makes sense since we used the door lock cylinder code to make the ignition key. Good to know the trunk key & glove box are the same.
