'40 Ford Hood Hinge
Roger W Gerow
One of those senior moments. Didn't take any pictures when I took it apart. At this point not even sure which is left and right side. Can someone post a picture of their '40 Ford hood hinge so I can install mine correctly? This is the hinge with the large spring on it. Thanks in advance.
Roger, Having Trouble Sending Pic. If No One Send A Pic. 419 509 5387
If You Call Me I Will Look At Mine And Talk You Through It.
Here are a few of my '40 I am also putting together after many (?) years! :o I know it's not a flathead, but it is a FORD. :) I do have two flat powered Fords! :cool:
Excuse the picture size. Got a new camera and will have to get used to it!
Big FE……….nice !
The last 40 hood I did I drilled the holes in the cowl a bit larger to get more adjustment.
Leave them lose….close the hood….push it (hood) around to were you want it….clime inside and cinch down the ones under the dash ….. Open it back up and tighten the others.
Pictures are worth a thousand words! These are just what I needed. Thanks to V8 Bob and 296 V8. Starting to put my '40 Tudor back together pretty soon.
