should i cover top and bottom of grill to get more air to motor or just top len
What top panel was factory installed?The stock 40 came from the factory with a top, bottom and side panels to help funnel the air into the engine compartment. Do you have them?
Nice setup! How is the fan mounted? Is it on the alternator bracket? What did you use on the crank for the narrow belt to drive the fan?
Nice motor, I had problems for years, try increasing the timing and the main jets on the carb. It worked for me. I was out yesterday in 95+ heat, on the road at 60 mph it ran @ 160 degrees, around town @ 180. I have a built 59AB in a '48 with stock radiator.
I was going to spend $600 for a Walker radiator but this is what they told me.........You will find the heat is in the motor not in the radiator.......
It cost me @ $20 to solve my problem.
"Don't chase a problem with money, you'll only go broke"...IRONBUTTJOHN
What size were in previously?Carb. Jets.....
I am using size 50 and with this poor gas it made a big differance
Stock mechanical fans just don said:They don't??? - maybe I should toss the mechanical fan in my 48 with a 302. I've only had in in there about 20 years and it usually runs at 175-185.
