40 Ford coupe rear height
My 40 coupe is stock height at the rear and it is 7 1/2 inches top of axle to frame next to bump stop.
Thank you very much. That is exactly the information I was looking for. It also tells me mine is already 1" lower then stock at 6 1/2. I will go for 5 1/2 ang I think reversing the eye should put me there...Thanks again
Thank you,and that's about what I'm going for.
Did this happen? Wondering how you made out, what parts you used, shock angles, etc. I'm doing a 39 std tudor and will be adding tube shocks to a lowered car. I haven't decided if I'll do a panhard or sway bar out back yet, sorta want the sway bar up front I think. From the "useless without pics" dept, the car and story can be found here:
https://www.jalopyjournal.com/forum/threads/39-standard-tudor-build-thread.985444/
Thanks in advance...
