M my40ford Member Jul 21, 2018 #1 Who sells small items such as original felt washers and etc that go to the steering column shift linkage for the 3 on the tree.
19Fordy Well-known member Jul 21, 2018 #2 Bob Drake has shift kit that includes rubber for column shift handle. https://www.bobdrake.com/FordItem.aspx?Item=01A-SHIFT-KIT C and G has kit, but comes without punch to assemble grommet. If you have a lathe you can easily make one. https://cgfordparts.com/ufolder/cgc...rchtextdesc=shift+kit&sd=Search&searchnumber= Dennis Carpenter probably has them also. Last edited: Jul 21, 2018
M my40ford Member Jul 23, 2018 #3 The parts I am needing on the attached diagram are:7314,7323,7337,351560-s,34746-s,351341-s.
19Fordy Well-known member Jul 24, 2018 #4 C&G Ford Parts has part # 01A-7323. I didn't check for the rest of the parts you listed, but give them a call. Sometimes a call is better than the internet. https://www.jalopyjournal.com/forum...kes-backing-plates-wheel-bearings-etc.956972/
corvette8n Well-known member Jul 24, 2018 #5 When I bought my '41 a box of column shift parts were in the trunk, most of the little baggies were marked Drake, I think a couple were from Carpenter, between them and C&G you should be able to get what you need.
