TJ
I'm putting together my 40 cowl vent mechanism and I need to know the sequence of the washers on the spring loaded bolt that passes through the lever arm and the bracket. There's three washers that are about 1 inch in diameter. One has friction ridges on one side of it, then there is a thin brass washer and last is a regular flat washer.
