40 coupe quarter glass seal
I have numerous times. The seals fit quite well. However, depending on the thickness of your glass, you may find it necessary to apply electricians' tape around the perimeter of the glass. Place this tape against the glass, the seal installed over it (the tape).
The original glass was a nominal 250".
Reproduction glass (Sanders comes to mind) is typically about .020" - .028" thinner. You need to make up that difference.
