40 FourDrDlx
Ok, I've been reluctant to post this for fear of sounding like a dumb-a**, but here goes. I've done clutches & trannys on later models, but this is my first go-round with the flathead & closed driveline. Is it normal to have clearance problems r&r-ing the trans? There doesn't seem to be enough room to pull the trans back far enough to get the input clear of the disc. Trans case hits support cross member & mount ears on rear bearing retainer won't clear frame & floor pan. I did finally get it out somehow with a lot of pulling, wiggling, & bad words! So, now its time to go back in-----What's the trick? Remove the rear brng. retainer? Guys have been doing this in driveways & backyards for 70 years! What am I doing wrong?
Thanks, Bob ( 40 four door Deluxe)
