40-47 ford cab
wallymelton
Will the 1940-41 ford 1/2 ton truck front sheet metal fit the 1942-47 ford 1/2 ton truck cab? What are the differences of the 40-41 versus the 42-47 cab?
Thanks for all the comments and help!
to make 40/41 sheet metal fit the later cab you will need to drill holes for the fenders to bolt to the cab-not much difference in the cabs-ford script on dash is different, fenders attach to the cab with two brackets instead of being thru bolted, floor is shaped different around the trans "hump"
