40/41 pickup bed
40fordpu
Hey everyone. Get some time to work on the 40/41 truck bed I purchased from Early Midwest Ford/NCT. Instructions are a little vague. Anyone have good build photos or even the original photos off NCT website??? Thanks
A few years ago I had posted some pictures of my bed assembly from Northern classic, 38-39's are the same as yours. If you do a search you should find that thread.
As I recall I had to fit the sub frame with the frame holes and then assembled the front and side panels. The fitting of my bed wood was next and with the S.S. divider strips that was probably the worst of it.
Also before I had the bed parts painted I fit and drilled out the fender mounting bolt holes. One of the first things I did do when I got my bed parts I had them cleaned and primed.
If you need I can dig out those instructions as they are probably close to what you have. Scott
What are you needing to know? How to put bed wood in? installing rivets? If Larry mondello is still around?
NCT had some great pictures on their website. Not up anymore. I thought I screenshot the pages when I heard they were moving on. Guess I "lost them". Starting from scratch so trying to figure out how subframe works with wood support etc.
Found some. In case anyone else needs these here you go. They were in a previous post I asked about. Thanks for everyones help.
