Don Rogers
As a followup to the previous posting on the subject, Here is a more detailed discussion of the subject.
The 40-2454 Clutch and brake pedal pad was used from late 1933 through mid 1936 without change (see Fig A). These original design pads were assembled to the pedal without a lock washer and tightened on the ¼” pipe taper thread.
There must have been an issue with this design staying firmly tightened on the pedal because in mid 1936 the pad was redesigned to have a longer threaded stud (.55” to .66”) (See fig B) This longer stud allowed the use of a lockwasher (34810-S2) to help secure the pedal pad to the pedal. (See fig D). The newer design pad also had two recessed holes to facilitate the use of a special wrench designed to help tightened the pedal pad to the pedal (See fig 144).
It was suggested in future service bulletins that the washer be used on previous pedal pad installations to provide a tighter and more permanent assembly(See fig C)
