I use a air operated chisel/hammer, ground an end on one of the punches to a little less than the pin dia. protect around the pin on the bottom of the hinge with a piece of rubber, then use a heavy glove to hold the air chisel and direct the end to the bottom of the hinge-start off with about 40 lbs and let it hammer. works like a charm
