I am restoring a 1947 V-8 1/2 ton truck with 4 speed. I would like to keep the truck as original as possible but all the info I read says the 4 speeds are hard to shift and should be replaced. When I got the truck from my dad it was not running and now I have it down to the frame. Should I be looking for another transmission? How hard are they to shift? What does double clutching mean? I read on another thread that the only transmission that will come close to bolting up is the heavy duty 3 speed with open drive. Will the heavy duty 3 speed bolt up without changing the driveshaft... I do not want to do any cutting on the crossmember!!! Thanks for any help...
