fomocoloco
went to NAPA today for a 4 pound cap for my new radiator. they can't supply one. anyone have a part number? car is stock 36.
None of the above 4 lb caps are going to work if you don't have the radiator or the overflow in the neck to hold the pressure. I am not sure about the 36 passenger car radiator . The 4 lb cap works on my 37 Ford but mayby because my radiator is the later 38-39 standard 81A replacement,I think the 39-40 Deluxe had the overflow configured that would not allow a 4 lb cap to seal. You may need to attain the pressure by installing Skips valve on the overflow tube.
