While it is true that you can get some real worthless junk out of China, It's wrong to automatically assume that its junk just because it is Made in China just like it is wrong to automatically assume that it is quality just because it is made in the USA. China puts out some quality stuff (but it's not cheap)and the USA puts out some junk. You have to loom at the actual product to determine it's quality, not it's country of origin. However, there is nothing wrong with wanting to support local manufacturers and therefore only look at Made in USA products. Just don't assume that it means they are quality. Bottom line, you can NOT get quality cheap, regardless of country of origin. You can, however get expensive junk so beware.My aversion to Chinese lift manufacturing is based on safety.
The Backyard Buddy web site used to have detail photos of lifts showing design differences that make you think twice about the Chinese ones.
I do understand that Chinese manufacturers cut corners mostly at the behest of US buyers who want lower prices.
If you specify what you want and are willing to pay for, it their quality is acceptable.
Words of wisdom here. Thanks!While it is true that you can get some real worthless junk out of China, It's wrong to automatically assume that its junk just because it is Made in China just like it is wrong to automatically assume that it is quality just because it is made in the USA. China puts out some quality stuff (but it's not cheap)and the USA puts out some junk. You have to loom at the actual product to determine it's quality, not it's country of origin. However, there is nothing wrong with wanting to support local manufacturers and therefore only look at Made in USA products. Just don't assume that it means they are quality. Bottom line, you can NOT get quality cheap, regardless of country of origin. You can, however get expensive junk so beware.
Ya but at least that brand stands up to the riggers of crushing a car! LOL
I'm thinking more that it is photoshopped. The yellow bar across the top is the safety switch to prevent such an occurrence and the bar appears to be still in the neutral position and not bent at all, the "wrinkles" in the door are un-natural and why would the roof pillars and windows be stronger than the doors and quarters?.I wonder if the (cheap) switch stuck on?
Anyone use the max Jack 2 post lift? I like the idea of being able to unbolt from Floor and with the attached wheels move the post out of the way when I need the room in my small garage.
Looks like the same 2 post i have. Bend pac, 10,000 lb, asymmetrical low profile. When I set mine up I went with the wide stance thinking about door clearance then found that the front arms BARELY reach the frame on a model A. Have to be dead centre between the posts.I just went through all this. It only took me 8 months to make a choice. I looked at most brands, talked to everyone that sold them within 250 miles and even paid a small REshipping fee to send the lift back after I decided to buy a different one.
I have a bendpak 2 post 10,000 LBS and a bendpak 4 post HD-7W. The bendpak, for me, seemed to be the best overall value. It’s not the most expensive lift out there but not the cheapest either. For me and my life I’m not trying to save every dollar I can on something I’m standing under that’s holding 4,000 to 5,000 lbs. I read many articles and reached out to many folks in this site.
One thing you will find is that there are a couple of manufactures that make most lifts and rebrand them. Most all are made in China except for backyard buddy, that I know of. Back yard buddy was super nice but also came with a price tag.
On a 4 post lift you can expect to pay 1800-2000 on the low end, 3500-4000 mid range and 4800+ for the back yard buddy stuff.
This is the first I've heard of this. I have, however seen that picture before. I wasn't there when this happened but I am pretty certain that the wreck was caused by someone lifting by the body and not the frame so the weight of the frame/drive train ripped the body bolts out. Whether that is true tor not I don't know (just my observation) but I am even more certain that it was NOT caused by a faulty switch. There appears to be zero damage to the roof of the vehicle and I fail to see how squishing ta vehicle against the ceiling would cause the frame to separate from the body. Again, just my observations.View attachment 457347
There is a weak link in many of the electric motor controllers used on many of these cheaper lifts both in 2 and 4 posts. There is an electromechanical relay used to control the ups and downs... The companies that use a Chinese made electromechanical relay have issues with the contacts welding themselves together. So sometime when you release the up lever it keeps on going up until it finally hits the safety stop. Oil change shops were getting sued when pickup trucks with tall camper shells were being accidentally shoved into the ceilings. The real high end lifts being sold typically use more expensive solid state relays that are contactless.
