Roger/Sacramento
This was how I went with 276 cube and three Max built Strombergs and an L100 from Ol Ron. Runs great.
with the air valve secondary adjusting the weight on the air valve makes it extremely tunable depending on your application
I use #51 jets on my Holley 390, List 8007 carb. Engine is stock 239 cu. in.
As I recall 390's come stock from Holley with #51 jets.
Nice PCV setup.
Sal
Nice use of a Ford 3g alternator too.Nice PCV setup.
Sal
#31 shows filtered intake air supply. #33 show the road tube mod replaced with the PCV.
your setup is the same but I chose to supply filtered air. Up in the north woods you are probably OK with an Unfiltered supply but down here in the desert SW dust/grit is everywhere
