gweilbaker
Where are you that gas is $4.45 gal?? Why won't people fill out the profile? At least what state you're in/ JMO
Paul in CT
Around the Chicago area easily, although it has come down a little the past week.
Paul in CT
Try 10 mpg on a 2000 F-150. Full tune up 2,000 mi ago.ken ct.
I like the Miles-per-Grin analogy !
I've been doing some hauling with the '61 Willys pick-up this last week.... 4.88 gears and about 9 MPG.
Ouchie.
...No way to add an overdrive to a FIAT transaxle.
With 4.88 rear gears that engine must really scream at 55 MPH, or will it go that fast?
My 1929 Chevy 1 1/2 ton truck has a 4.88 ring and pinion and it sounds good at 25 MPH.
I bought a FIAT 850 engine at a junkyard auction for $21, and just won a transaxle for it on ebay. The seller said it was also 4.88, which is a bummer because I'd like to make a small econo car or trike out of this. No way to add an overdrive to a FIAT transaxle.
A model A cost approximately $500 in 1930.
A new typical sedan today would be an easy $20,000.
That's 40 times more money.
Divide even the price noted on this thread by 40 and your get about 11 cents...............which is about what a gallon of gasoline cost in 1930.
