theriddler56
4-1/8” crank
Has anyone ever tried offset grinding a Merc 4” crank using 21a rods and rod bearings from a 98-2000 and up 4.6L ford engine. It appears to be doable as the 4.6 rod housing bore is only .018” larger than the 21a rods. Using 4.6 rod bearings that are 1.000 mm undersized (.040”). It would appear one would have to grind the merc crank to 2.046”. Is there enough meat on the merc rod journal to accomplish this?
