reddog565, Thanks for the compliment on my car. Still thinking about your problem, but haven't thought of anything other than what has already been posted. I still think that if you can choke the eng. with your hand over the carb. opening with your hand a little and the eng. speed increases, or has a better smoother idle , that you have a vac. leak somewhere. do not rule out the possibility of the pcv valve being the culprit. find one for a Ford or Chevy eng. for close to the displacement of your eng. if you have a 292-312 one for a 292 chev. six, a 289/302 Ford, 283/327 Chev. should all work what make and size eng. do you have? what brand Intake manifold. some of the early intakes do not seal on the later Y-Block heads, and the Offenhauser 3x2 manifold is the worst for performance of them all. ( I do have one on my car, because that is what was on it when I bought it, and the others are non existent here in Alaska , and expensive else where+ the cost of shipping. ) Check out Ted Eaton's web site for flow testing of many manifolds and carbs, and a wealth of other info. Also check out John Mummert's site lots of good info there also. hope you get your problem sorted out keep us all up to date.---Jim
