Karl Wescott
I have had very good results using PRUSA mini's, though I have worn a couple out. I am currently using a PRUSA MK4 with excellent results. I had a Sovol SV06 that worked OK for a while, then bricked.
what is you layer thickness? .12mm?
If you want a slightly larger printer that doesnt break the bank, I'd highly recommend the Qidi brand.
You're doing a EXCELLENT job!
Thanks! I have the layer height at 0.08 and the line width at 0.4, which is the lowest I can go with the .4mm nozzle. I can drop that down to .04 and .15 with the .2mm nozzle.
Try lying to the printer... use the .4mm nozzle and the .2mm presets in the slicing software. I do something similar with my PRUSA's, .6mm nozzle (I use a metal filled filament) with the .4mm presets.
I don't think I can use the . 2mm nozzle with that, which is needed If I want to mimic that super fine detail of the caps Ford stamping. I'm thinking about spraying it with a textured paint and then grey to make it look more cast.Karl, are you using the Protapasta filament? I have always wanted to try it. It might look neat for him to use such on the "lead bars" of the battery.
I know it would be mixing technologies and not what you are intending to do; but due to that complicated pattern wouldn't it possible to pull a mold off an original case and cast the side and end panels out of resin and in the same light cast the cell connectors out of lead.
