Have been around points-equipped Fords for decades and never had this much difficulty getting spark..
390 has new plugs, wires, cap, rotor, condenser and battery/cables. No spark. Ground wire inside distributor to points is fine, though I had also switched that too when nothing else worked.
Hotwired coil direct to battery positive, still no spark.. After checking coil + and - wire continuity with multimeter, I have one at a time changed out everything at least once. Even replaced the entire distributor and coil from known running engine and hotwired coil direct to battery.. Still no spark... Distributor rotor does rotate when the engine is cranked.
Starter seems to crank the engine normally which I have seen in the past that a starter that draws too much amperage can diminish power to coil enough to prevent ignition function. But that does not seem to be happening here.
What could it be? Been through 3 coils, 2 rotors, 2 condensers, 2 coil lead wires, and finally the entire distributor. No results. Am in my 3rd day of this rut...
