Thanks for all the input so far.
The engine is equipped with a converted SBC distributor and a 12 volt system. Vacuum advance is hooked up to the carburetor's timed spark vacuum source.
I have an electronic fuel pump running inline between the tank and the mechanical fuel pump, but with the pump both on and off the result is the same. I can only get the engine to run for a few seconds.
Never adjusted the float bowls - unfortunately, the instructions say that the car has to be idling to make that adjustment. Does anyone have a method for doing it while the engine is off?
Thanks again,
Nick
