Tudortomnz Well-known member Oct 7, 2011 #1 I've just found 2 'free standing' Ford script trims . Each is 5" long & has 2 attachment pins spaced at 3". Would they fit the '39 standard hood sides or the later '41 '42 p'up hood? Thanks
ford38v8 Well-known member Oct 7, 2011 #2 From the description, I can say with some confidence that they'd fit any Ford you'd wantr them to fit.
39 STD Senior Member Oct 7, 2011 #3 The hood side script on a 39 Standard is only 3" long with 2" between the pins.
