Yup, looks good from here. Make sure the forks are each in their center detent before bolting the lid down. Insert the lever, then push the small locating pin (not in your picture) through the hole in the top of the tower into the slot in the lever. The washer, spring and two round pieces that hold the lever in place are in the right order. Screw the top piece down onto the tower and you are set.
Will Kimble
Will Kimble
