Bored & stroked, Series N Thomson shafting is maximum 0.0002" undersized, while the material pictured is maximum 0.001" undersized. I understand the convenience of having a soft end to drill through, my machinist says it not a problem for him to drill and cut the hardened shaft. I prefer the fit of a properly sized shaft in the case ( O-ringed) and bearings that were designed to run on a 0.750" shaft. Am I overlooking something, do you see any reason why a series N shaft should not be used? I am interested in your thoughts.
Tom
