39 transmission bolt question
BarryBrosRacing
I’m looking for a source for bolts for the rear of my 39 transmission. Specifically I am looking for the 6 rear bearing retainer, 4 clamshell to bearing retainer, and 2 clam shell bolts. If there is no source for a “kit” can someone tell me the sizes I need?
Thanks
vanpeltsales.com has a ton of info and knowledge for free. thirdgenauto.com has knowledge and info, he also may have the bolts…….Mark
Bear in mind, the 4 bolts that hold the clamshell are fitted bolts.
the housing may well be worn, so new bolts will be loose, this will effect the U/joint and driveshaft concentricity with the gearbox output shaft.
Lawrie
Third Gen Auto in Tenn is also a possible source for the bolts. The 6 bolts to retain the rear bearing mount are drilled head for safety wire.
Thanks
I have them if you are still searching. Private message me.
