1930ABONE Member Aug 30, 2011 #1 Hi, Is ok to run a 39 trans conversion with the lightened A flywheel/V8 clutch? The Macs catalog implies you need to run the stock A trans? Thanks for any help! Tom
hardtimes Well-known member Aug 30, 2011 #2 1930ABONE said: Hi, Is ok to run a 39 trans conversion with the lightened A flywheel/V8 clutch? The Macs catalog implies you need to run the stock A trans? Thanks for any help! Tom Click to expand... Tom, I have a '39 trans with lightened flywhl and V8 chev pressure plate/disc, attached to a B engine. Runs nice/strong. You can get the 'kit' to do the change from Sacramento Vintage Ford and others I'm sure.
Jason in TX Well-known member Aug 30, 2011 #3 39 trans/lightened flywheel/V8 clutch/Volvo overdrive Makes for an enjoyable drive!
hardtimes Well-known member Sep 1, 2011 #6 Jason in TX said: 39 trans/lightened flywheel/V8 clutch/Volvo overdrive Makes for an enjoyable drive! Click to expand... Oh yes, and with zepher gears/qc rear!
