Curt,
If you are still out there keep something in mind when you reassemble your
trans...this relates to 2nd gear. It's a very bad idea to reuse the 'bushing' that 2nd
spins on, this is one of those obscure details that when overlooked can bite you hard.
2nd gear ideally should have .007 -.010 end play between its two thrust washers.
You'll notice that the front thrust face on the gear is almost non existent. At times
to achieve acceptable end play the gear might need to be replaced....big shocker
right. Too much end play and/or excessive clearance between the ID of the gear
and OD of the bushing is a cause of the dreaded 2nd gear jump out.
Charlie ny
Mac VP and I have all the parts you'll ever need if you need 'em. Macs
book is the BEST insurance you can purchase for success in rebuilding
your trans !
