HDowse
I'm almost done with the rebuild of the '39 early synchro style transmission thanks to Mac Van Pelt's book and many hours of learning. The last item to fit is the throw out bearing. In the picture, the hub and bearing that are on the transmission are on top with the inside and outside dimensions as close as i could get them. The critical measurement is the OD of the hub and the ID of the bearing, both nominally at 1.97". The replacement bearings I have purchased are both too big in the ID dimension and larger also in the OD. The lower left bearing is boxed as a B-7580 and the lower right is an A-7580, designed for '28-'48 transmissions.
My question is what do I have with the original hub and bearing? Do I have the correct hub for the transmission and what is the bearing? I may have to buy a new hub with bearing and hope that the ID of the hub fits the front bearing retainer. It doesn't appear to be for a V8-60 or is it? The bearing with the transmission is OK but as Mac say, it's best to replace it. Any help is most appreciated.
