My Father converted his 28 Model A to use a 39 steering box and drag link assm, the problem I am having is trying to figure out how the use an OEM horn rod assm by lengthening it so I can use an OEM wiring harness instead of some kind of universal switch and horn button like he used. He attached the lower 39 unit to the upper 28 column, I know the items work since it was in there before the restoration started. I tried to make an end plate with a tube to get above the oil level like the one Snyder's sells for the 28 Model A. The horn rod is 3/8" dia, the sleeve dia is too large to go into the bottom of the steering box.
1- How did Ford originally keep the oil from leaking into the switch?
2- Does anyone make a sleeved endplate unit that the rod will go thru and fit into the bottom of the steering box?
3- I can figure everything out once I get past the leaking issue.
I know this sounds confusing, if it would be easier, please call me.
Thanks, Ron 614 309 1513
