Hivolt5.0
Hopefully the Title covers everything, haha.
The steering box on this 39 Ford Deluxe was leaking and a good friend, 40 Cpe, here on the FordBarn told me about the common problem where the brass tube that attaches to the end plate will crack/break. So I pulled the end cap off the steering box last night and this is what I found.
The end cap came off by itself and I had to pull the brass tube out of the steering box.
As you can see, the brass tube has a nice flare on its end, but the cap also has a brass fitting in it (this is the exterior side of the cap).
And this is what the other side of the cap looks like (the side that faces inside the steering box).
The brass tube is the same diameter as the brass fitting in the end cap and thus will not slide in it.
What should I do? Do I leave the brass fitting in the end cap and silver solder the brass tube to the back of it? Or do I remove the brass fitting from the end cap and slide the brass tube in the end cap?
I would appreciate any advice you guys can provide.
thanks
David
thanks
David
