39 radiator removal
oswego37
I'm removing the radiator from 39 deluxe. Do I need to remove the inner fender braces and the horns to get it out? Thanks in advance
Horns shouldn't need to be removed.
The 2 brackets that run from the inner fender to the radiator will have to be removed ( if the car still has them attached )
You may also want to take out the fan for ease of access.
Braces have to be removed.
Braces (Part number 8046) have to be removed. You'll have to remove the fan assembly also so as not to damage your radiator. I altered mine but they look like this photo.
Please excuse double post.
Ernie, horns can remain in place. Gosh, I see you're in Oswego. Went to school there and worked at Northern Steel Corp. and the Speedway in 1967. Still remember the cold.
