39 pickup cab supports
rbabb
does anyone have a pic or know how many supports the cab has just behind the seat back. this looks to support the window frame?mine shows one with drilled out spotwelds where it should go but it came with two thanks
Hi, this picture should say it all. Good luck!
rbabb, my 39 cab is @ maaco in portland. Like johns picture it has two. We added a horizontal piece between the two for strength. My truck had a stake body and the rear cab wall was pretty thin and punky from the wet wood. Stop in and see marc or ashley, there crew did a great job on rebuilding my floor and seat support. It'l be there till the snow melts off in april!!
The 38 I have in my shop has two, while my 39 had one, in the center. I discovered there are many little differences between the two, with the 39 always using less steel.
my 39 has two exactly like John Mc,s in the photo allthough it is a 2 ton cab with the feul tank on the side of the cab
well iguess i have two options put one in the middle where it was or put both in like john mc pic do i need more support what u guys think?
friend with a 38 connected the two existing supports be cause his back panel "oil canned" and that was the easiest way to fix it
I have a rear garnish molding if anyone is interested. See the for sale section. $50 Bob
