36tudordeluxe Well-known member Nov 25, 2018 #1 This may be of use, print out to acetate and then easily transferable to frame member. Attachments 39pedals.pdf 39pedals.pdf 397.5 KB · Views: 147
JM 35 Sedan Well-known member Nov 25, 2018 #3 I was able to download and open this pdf file using my phone. Bob Drake supplies a drawing like this with his repro '39 peddles.
johndee138 Well-known member Nov 25, 2018 #4 Bobs pedal pattern required a bit more than the pattern called for when I installed a set of his pedals in my 36 Just sayin
ford38v8 Well-known member Nov 25, 2018 #5 Lawson Cox said: Can't pull it up. The attachment that is. LOL Click to expand... Lawson, your flip phone needs a software update!
Tinker Well-known member Nov 25, 2018 #6 Ya that pdf will work fine if it prints 1/1. Drakes is a good pattern. Modify if needed.
