39 pedal template
jerry grayson
At one time I had a template to show drill hole locations for installing 39 pedals in a 35 frame. I can not find it now. Can any one help? Thanks
All 39 pass chassis have a mirror image cut out on both sides ( for LHD and RHD )
Just need someone to get under their 39 with a piece of cardboard pressed against the RH side cut out and trace the outline and holes.
I'm too far away - by the time I'd sent it you the job would be done.
Good luck.
Chris.NZ.
Jerry, Bob Drake has a template that comes with the '39 repro pedals he sells. I believe Bob or someone else posted a copy of that template here. If you could find that post by doing a search, you could down load that template, size it 1 to 1 and make some copies on your printer.
Here is a post on the same subject. Looks like Richard Lacy, Early V8 Garage, has a template. You could contact him for a copy.
http://www.fordbarn.com/forum/showthread.php?t=5910&highlight=39+pedals
Here is the post I was originally referring to. Includes PDF of Drakes template
http://www.fordbarn.com/forum/showthread.php?t=124032&highlight=39+pedals
Jerry: I have one but I am in Texas for another week. I'll check in with you when I get back in town. Lawson
Drake's template, not sure how accurate it is printed out; but a comparison with your pedal assy will let you know if any adjustments are needed. If I remember right it was OK when I added '40 pedals to a '37 frame.
