‘39 pedal clarification
P.Stachlinski
New member
Hello everyone. I’m new here. Thank you for accepting me. I have a few questions that I’m sure have been asked many times before. I have a ‘36 5 window that I took completely apart 22 years ago and I’m rebuilding it now. It was converted to juice brakes around 1957. When it was done they cut the original brake pedal arm off, mounted the master cylinder to the firewall and left the stock clutch pedal in place. I want to convert it to ‘39 brake and clutch pedals. Here come the questions: the pedal bracket I have is P/N 01A-2467. I believe it’s for a ‘40, but not completely sure. If so will it accept ‘39 pedals? The arms that came with it are P/N 48-7520-A2 and P/N 09 2456 or 8. Hard to tell. I believe they are wrong because the shaft on the clutch pedal was too long and spaced out with a large lock washer. I have another juice pedal assembly but that doesn’t look right either. I’ll post part numbers after I clean it up. Thanks for any advice .
