"39 & otheryears, dim lights
Don Cape Cod
Bud's '39 has had dim headlights and he has been badgering me to correct the problem. Finally got to it. Turns out, there was only a little over 4 volts delivered to the bulb socket when the lights were on, either hi or low. There was a major voltage drop in the harness. Turns out that under that tin shield on the firewall, where the dash & headlight harness connect, the connection was warm to the touch. That is where the voltage drop was occuring.
Instead of replacing the old style connector & sleeve, I replaced it with the yellow (10/12 guage) modern crimp connectors. I also made sure by soldering the wires, as well as crimping.
I can tell you that from now on, when installing a new harness, I will use a modern spade type terminal. Would hope that I could get Tyree to incorporate this change in the next harness I order.
Bud's still not excited over the improved lights.
Another major problem with early lights is the ground because of all the fenders, braces and frame mounts that the ground has to go thru. I solder a connection directly to the headlight reflecter and sneak a ground wire from it thru the conduit to the frame and attach after cleaning a good bare spot on the frame. Makes a world of difference.
Did you solder before or after crimping? If you soldered BEFORE, and there's a voltage drop through the joint, it's possible that the heat could soften the solder and create a whole new problem.
