39 Mercury Driveshaft Part
FlatheadGuy
New member
SW
Nebraska
Need a forward yoke for 1939 Mercury open drive. Or complete driveshaft. Also would appreciate information on what else is applicable to 39 Mercury gearbox...******.. Perhaps, early 50s Ford pickup?
Bill 308-352-6364
I always thought the 39 Merc had a closed drive-line but the drive-shaft was a solid piece (no coupling) from the pinion gear to the transmission u-joint and longer than the Ford. I believe the 39-up Merc rear trans mount was different from the Ford and I may have one. The u-joint (yoke?) should be the same as a Ford.
