L lignell Senior Member Oct 23, 2018 #1 my 39 ford original engine still 6 volt with alternator,starts up runs for about 20 minutes and then shuts down and will not no spark but after awhile it will start and repeat the same procedure help thanks tom
D Don W/Norfolk Senior Member Oct 23, 2018 #3 I would check for a bad coil. Classic symptoms of a coil opening/shorting after getting warm/hot. dw
Chris in MA Senior Member Oct 23, 2018 #4 Bad Coil and or Condenser. Send them to Skip Haney. He advertises in V8 Times.
slowforty BANNED Oct 24, 2018 #7 I had a problem with my 6-Volt alternator. It was not putting out enough Amps. So the car ran poorly. Have it checked out .
