39 ford window reveal help
wisbangman
Hi Barnners ! .......I need to remove the inside window revel moldings on my 39 Standard 4 door Sedan. The 38/39 book shows photos of the spring claw clips, that hold the moldings in, but I still have some questions.
1. How many clips does each window have ?
2. Where is the placement of the clips ?
3. What type of tool should I use to remove the clips ?
4. Are there any tricks or tips in removing the clips / moldings ?
5. Are there any tricks or tips in the reverse install ?
My door panels are real nice and I'm wanting to keep them nice.
Thanks in advance for your help.
On my coupe, if I remember, there's a total of 5 per frame. 3 spaced along the top & 2 on the vertical side. There is also the inner door frame that holds them on the bottom.
To remove, roll window down, slide frame as far forward as possible while pressing down on frame. Then the top of the frame can be popped out, from the top, using only your fingers. No tools needed.
