- City
- Chico
- State
- Ca
- Price
- within
39 Ford series 60 hot rod project..I've been working off and on on this for the past 6yrs and since I am not getting any younger,I want to pass it on to someone that has more time to dedicate to it..
Rust free cab,bed+original frame since this truck has always lived its life in Ca. and Idaho..and is currently titled in my name in CA and non-opped..Glass is in it...
87 Iroc Z roller 305 motor,700R4 and disc brake 3"42 posi rear..Motor is currently set-up with and Edelbrock semi-high rise with a small holley on it,but I still have the original TPI with harness and brain if you want to go down that road instead..Exhaust is run from the manifolds to just after the rear end..Had the motor running a year ago...driveline had 78k miles on it...A-arm front suspension with GM disc brakes and rack and pinion...Brakes were plumbed and bled at that time,but I since had to drain the resevoir,so it needs to be done again...You'll need to connect the tilt column that comes with it to the rack,wire it,and complete the cooling system for it to be able to run ...Nice winter project....$4600.00..707-292-3033/Rick,or knuck39atyahoo for more info..
