I need to pull the oil pan from my 24 stud 221 cid 39 std to clean out the sludge in the bottom. Plan to remove radiator hoses and fan, jack engine, remove engine mounts, and block up the water pumps to get clearance over the crossmember.
Can I get enough clearance doing this without undoing stock style single exhaust and engine stay rods?
To get the pan out from under the car do I also need to remove the drag link and tie rod or just lower the wishbone by dropping down the ball under the transmission?
Thanks in advance!
Thanks in advance!
