Im replacing my dist to my 59ab motor and found it has a extension button between the dist and cam, is this normal ,or dose it meen something has been updated or changed
You mention you are using a 39 distributor on a 59AB engine the thing that is probably changed is the front cover. The adapter you mention is a Ford part enabling using the early distributors 37-41 on the later camshaft front.
