BillW810
Another newbie question. The bosses where the hinge attaches to the hood are stripped. T-nuts were suggested as a repair. A couple of questions if you have done this.
How did you remove the stripped boss? It doesn't really look like a spot weld like for body panels. The 'spots' look too defined like they were drilled. See pics. I guess the backs are ground off, tedious.
Or cut The boss, grind flat weld T-nut to engine compartment side. No need to remove hinge 'plates'. I had to remove 1 side to straighten the plate.
Pic 1 is "engine comp", pic 2 is "hood side"
