The yellow wire goes from the solenoid (same (drivers) side as the battery cable)to the circuit breaker where it is on a common terminal with the wires going to the ignition switch and the cigar lighter.
If your jumper wire followed the same path, then look for a break in the wire, probably near one of the terminals.
If you connected to the breaker terminal with the yellow wire with a red tracer, you may have a bad breaker.
